AzJazz
Dec 13, 2016Apprentice
Orbi Router configured for Region = North America, Orbi Satellite Region = Europe
Hi - I have my Orbi Router configured for Region = North America (This setting appears to be unmodifiable). However, my Orbi Satellite has Region = Europe. Can I change my Satellite Region = North...
JustATechieKind
Dec 16, 2016Aspirant
I had the same issue. Support had me update the firmware in the satellite and then the router to the current release. Once the firmware was on the current release, they had me perform a factory reset on the device. When I logged back in, the satellite was set to North America. They said a software "ease" (in settings) works most of the time, but sometimes you may need to do a reset to defaults using the pinhole button on both the satellite and router.
- AzJazzJan 07, 2017Apprentice
Do all the Orbi devices need to be Factory Reset, or just the Satellite?
I have just backed up all my v1.4.0.34 settings, and I want to reinstall them afterwards (I have a ton of customized settings). I hope that the satellite's region isn't one of the saved settings.- swrtwdrvJan 07, 2017Apprentice
Just the sats.
