PHFG
Jun 05, 2017Aspirant
Orbi Router Converted to Orbi Satellite?
Can an Orbi 2200 router be configured and used as a satellite in an Orbi system?
- Jun 05, 2017
hi , no i dont believe it can , it can however run as an AP instead of a router
im assuming you want to buy 2 orbi kits and use the second router
PHFG
What is an AP? I do have two Orbi kits. I use one router and I have four satellites. I want to use the second router to fill a weak signal area if possible. What is an AP?
