ChrisPartridge
Sep 04, 2017Follower
Orbi router in bridge mode over ethernet?
My modem/wireless router (a BT Home Hub) is located in a corner of a house with concrete walls that are very bad for wireless signals. To provide good coverage throughout, I want to connect place the...
DarrenM
Sep 06, 2017Sr. NETGEAR Moderator
Hello Chrispartidge
You either want to bridge the Home hub or set the orbi in access point mode but not both.
DarrenM
- timchSep 06, 2017Luminary
To make this work your only bet is to have the Home Hub connected to the Orbi by Ethernet or as a last resort by a couple of powerline adaptors. You will need to set the Orbi in AP mode assuming you have a recent home Hub which will only work in router mode.
My Orbi gives very impressive coverage through walls placed next to my home Hub at the front of the house on the ground floor with the satellite at the back on the first floor. I get great coverage down into the basement and up to the second floor.
