Orbiuser1985
Feb 15, 2019Aspirant
Orbi router issues
My RBK 50 has started dropping the internet connection again which is something that has happened several times in the past. When it does, I normally resolve this by performing a hard reset of the router and satelitte and set it up again.
This time however, my problem persists. The router continues to drop the internet connection and I dont know what to do. I've hard reset the router 3 times now while the satelitte is disconnected just to see if I could get the router to be stable. But it was without any success.
I am now reaching out to the community to hear if you have any final ideas.
I am running firmware V2.2.1.210
Is the Orbi system operating in Router or AP mode?Any Wifi Neighbors near by? If so, how many?
IPv6
- Orbiuser1985Aspirant
All wireless radios on this gateway disabled and turned OFF>?
Orbiuser1985 wrote:
Its a genexis router:
https://genexis.eu/product/hybrid/
Ap mode
no wifi neighbours nearby
- randomousityLuminary
Have you done any troubleshooting with the modem?And, just to be clear, it's the fiber box that's in AP mode, right? Have you tried bypassing the Orbi and connecting a device directly to the fiber box to test that it's not the fiber connection or box that's having issues? And does your Orbi get an IP address from your ISP via DHCP? Or it it manually assigned?
