jolson490
Jan 12, 2021Aspirant
Orbi router RBR20 intermittent connectivity issues
Last April from Best Buy I purchased a new Orbi AC2200 - the box says RBK20W, and it includes an RBR20 router and an RBW30 satellite. It's worked mostly ok til about a month ago I started occassionally being unable to access the internet from my laptop which is connected to the RBR20 via wifi - it's gotten to the point that quite a few times a day my internet connection will cut out for about a minute or so.
fyi:
- 1,500 sq ft home
- My two laptops are in my office. Both my modem and router are in the bedroom across the hallway from my office, so about 25' away.
- Channels I'm using: Auto for 2.4GHz, 48 for 5GHz, and 157 for 5GHz-2.
- On my RBR20 the "Router Mode" is selected (as opposed to "AP Mode").
- I do not have any of the following enabled: Armor (security), Circle (Parental Control), nor Guest WiFi.
I've tried the following things, but my internet connection still keeps cutting out:
- I got a new modem from my ISP, Spectrum/Charter. (My house is only 20 years old and I've had Spectrum come out and verify the wiring in the house is good.)
- On my RBR20 I updated the firmware version from v2.3.5.30 to v2.5.1.16
- Per https://community.netgear.com/t5/Orbi/RBR20-Satellite-when-enbled-causes-intermittent-internet/m-p/1950228/highlight/true#M98508 I enabled BEAMFORMING, and per https://community.netgear.com/t5/Orbi/RBR20-Satellite-when-enbled-causes-intermittent-internet/m-p/1953580/highlight/true#M98985 I unplugged my satellite.
- On https://orbilogin.com/adv_index.htm:
- Setup, WAN Setup, per https://community.netgear.com/t5/Orbi/Repeated-DOS-attacks-causing-dropped-connections/m-p/1851771/highlight/true I checked/enabled "Disable Port Scan and DoS Protection". (Though I'm not sure if the "DoS Attack" lines in the attached log file are the cause of my internet connection cutting out.)
- Advanced Setup, Wireless Settings, I changed "Transmit Power Control" from 100% for both 2.4GHz & 5GHz to 50% and 75% respectively (per https://www.reddit.com/r/orbi/comments/fov5z4/connection_drops_every_30_seconds_with_orbi_rbr20/ and https://windsorwebdeveloper.com/making-netgear-orbi-great-again/).
I still had my old tp-link router in my closet, so I unhooked my RBR20 and hooked up the tp-link and the internet is working consistently. So it seems the RBR20 is the cause of my issue.
Any suggestions for how to get my Orbi to work reliably would be much appreciated. Thank you!
Glad the ISP took care of the problem.
Please mark your thread as solved so others will know.
Enjoy. :smileywink:
- vajimMaster
"On my RBR20 I updated the firmware version from v2.3.5.30 to v2.5.1.16"
Before or after the problems?...a month ago...??
25ft maybe too close. 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
jolson490 wrote:Last April from Best Buy I purchased a new Orbi AC2200 - the box says RBK20W, and it includes an RBR20 router and an RBW30 satellite. It's worked mostly ok til about a month ago I started occassionally being unable to access the internet from my laptop which is connected to the RBR20 via wifi - it's gotten to the point that quite a few times a day my internet connection will cut out for about a minute or so.
fyi:
- 1,500 sq ft home
- vajimMaster
- jolson490Aspirant
vajim: The problem started about a month ago. The bullets in my "I've tried the following things" list are things I tried yesterday. So the problem occurred with both firmware versions.
FURRYe38:
* My modem says Spectrum on it, the model is ET2251, and it also says "Docsis 3.1 eMTA" on it.
* Please correct me if I'm wrong, but I don't believe the feet/distance matters because I've unplugged the satellite.
* The screenshot I'm attaching shows the wifi networks near my laptop.
* I have not yet tried a factory reset on my RBR20 (but I can/will if that's what you recommend).
