LindaD
Aug 12, 2025Aspirant
Orbi router RBR40 question
I have an Orbi router RBR40 and it came with (3) RBS20 satellites. I added (1) RBS50 satellite. I know my router is too old to do a firmware update on the router. At this point I can't really af...
Aug 13, 2025Guru - Experienced User
I've seen a few people on here with quite a few satellites. You can add more. Plus the older 20/40/50 series are pretty cheap. You might even find a used RBK53 set so you can switch to the 50 series with the wider backhaul. plus then you have extra's. On my local face page marketplace, they're running $25-50
