jpatl's avatar
jpatl
Orbi Router
We recently upgraded our modem.  It is also in a different location.  I follow the Orbi app instructions but when I get to the step where it instructs to connect to the Orbi Wifi, that Wifi system does not appear on my phone and the app says it does not recognize our new Wifi.
I'm only moderately tech savvy but can follow what seem like simple instructions on the app.
What am I doing wrong?
  • CrimpOn's avatar
    CrimpOn
    Was this Orbi working with the old modem?
    Can you identify the brand/model of the old and new modems?
    • jpatl's avatar
      jpatl
      The old modem was ATT Arris BGW210.  The router did work with this modem
      The new modem is an ATT Smart Home Manager BGW320.
    So you are saying you don't see the Orbi Wi-Fi network name (SSID) and password located on the bottom label of the Orbi router?
    Is the light on top of the Orbi blinking white?
    Since you upgraded your modem, depending on which modem it is, you may have to reset it or reboot it. You will more than likely, since the Orbi router was connected to the previous modem, factory reset your Orbi router.
    • jpatl's avatar
      jpatl
      I see the SSID and OrbiWifi on the router but when I'm using the app on my iPhone, the Orbi WiFi network doesn't show up on my phone.   Is it supposed to be somewhere else?
      I have rebooted the new modem several times (as the app instructs).  I have not reset the Orbi router to factory settings.  Shoud I try that?
      Thanks
      • Mstrbig's avatar
        Mstrbig
        Master
        Thanks
        What phone do you have? The app won't show the WIFI. You need to go on the phone's WIFI and sign into it.
        Did you reboot the BGW320 before setting up the Orbi?
