pfeatherstone's avatar
Dec 22, 2021
Orbi Router(RBR50) satellite dropping internet connection
I'm afraid I dont have a degree in networking but I can tell you that my Orbi Router(RBR50) continues to lose internet connection from one of the satellites.
Drops for 10-15 seconds multiple times a day knocking me off video calls. Always returns after this short period of time. The connection is visable still but showing no internet.
Has been an issue with multiple laptops over the last few years, initial advice to update firmware has had no effect. It is updated to the latest version.
Any help much appreciated.
Thanks!
Paul
  • plemans's avatar
    Its only when connected to one of the satellites?
    Have you tried swapping satellites (power off the other one) to see if you can narrow it to being a specific satellite?
    • My wife uses satellite downstairs for work and has no issues, I should change over to also test but don't want to risk inflicting issues I have on her!!
      • plemans's avatar
        If you shut the one down that you're using, does it experience drops?
