minkus's avatar
minkus
Orbi routers
Is it possible to use my old Orbi Router and satellite with the newest Orbi system in order to expand the range of my current setup?
  • plemans's avatar
    What actual systems do you have? It matters model wise.
    Will a new AX system integrate with the old AC system? No. but you could connect the old system in access point mode (with different ssid/wireless channels) and use it in conjunction with the new system.
    • minkus's avatar
      minkus
      I have an RBR20 main router and RBS20 satellite.
      So they won't work to extend the range? only as access points?
      Would that mean that if I was on the other SSID any networked devices on the new ssid wouldn't work? (or opposite if I changed the ssid on the newer routers to what is existing)
      • KevinLiT's avatar
        KevinLiT
        NETGEAR Moderator
        Hello minkus,
        Welcome to NETGEAR Community!
        I understand that you are looking for information about compatible devices with your RBR20.
        The RBR20 is compatible with the following Orbi AC Satellites -  RBS10, RBS20, RBW30, RBS40, RBS40V, RBS50, and RBS50Y.
        Best,
        Kevin
        Community Team
