UKNoob
Jan 24, 2021Aspirant
Orbi RVK20 no internet connection
Any help gratefully received. We have an orbi RVK20 and satellite. It previously worked well but we have taken delivery of a new Virgin media superhub 3 and despite initial success we cannot connec...
Jan 24, 2021Guru - Experienced User
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
We have an orbi RVK20 and satellite. It previously worked well but we have taken delivery of a new Virgin media superhub 3 and despite initial success we cannot connect to the internet.
The orbi is connected to the superhub 3 with an ethernet cable. The sh3 is modem mode. Our mobile can detect the orbi but there is no internet connection.
We have tried setting the orbi to AP mode with dynamic IP address. We have power downed and done several factory resets. We can't log into the router through its IP addresses despite clearing caches.
All rather frustrating and it looks like we will have to abandon the orbi and switch the router back into WiFi mode before we all resume working and studying from home unless any of you kind people can suggest something else we can try.
UKNoob
Thank you for your reply. That does sound quite complicated to me. I think I'll take a go in slower time. Otis shame the new Hub3 isn't as compatible as the ancient superhub we've just replaced! We need the WiFi to be good and reliable as 2 of us are working from home with 3 teenagers doing online schooling and online living at the moment.
- FURRYe38Jan 24, 2021Guru - Experienced User
Option #3 would be the easiest for you.
UKNoob wrote:
Thank you for your reply. That does sound quite complicated to me. I think I'll take a go in slower time. Otis shame the new Hub3 isn't as compatible as the ancient superhub we've just replaced! We need the WiFi to be good and reliable as 2 of us are working from home with 3 teenagers doing online schooling and online living at the moment. - vajimJan 24, 2021Master
UKNoob wrote:
Thank you for your reply. That does sound quite complicated to me. I think I'll take a go in slower time. Otis shame the new Hub3 isn't as compatible as the ancient superhub we've just replaced! We need the WiFi to be good and reliable as 2 of us are working from home with 3 teenagers doing online schooling and online living at the moment.good conversation here:
https://community.netgear.com/t5/Orbi/Orbi-RBK50-and-Virgin-Superhub-3/td-p/1678276
glad we could help
