bradstraarup's avatar
bradstraarup
Orbi Satelitte RBS50 Pulsing White
Hi there, I'm having trouble setting up my Orbi RBS50 Satellite. The satellite continually flashes white (not pulsing white).
  • I've tried pressing the reset button. The satellite doesn't respond and continues flashing white.
  • I've tried holding the reset button for 30 seconds. Then turning off the router while holding the reset button (30 seconds). And then turning on the router while still holding the reset button (30 seconds).
  • I've tried plugging the satellite via ethernet into the router. The router doesn't pick it up.
  • I've tried plugging the satellite into my Mac via ethernet and manually assigning an IP address. But that doesn't seem connect.
  • Additionally, trying to sync the satellite by pressing the buttons on the back doesn't work. It continues to flash white and not respond.
