RudigerGatt's avatar
RudigerGatt
Orbi Satellite Addons
Hey everyone, ive been researching alot about mesh networks, im moving into my home soon which consists of 2 floors. Ive seen a number of reviews and from the looks of it the nergear orbi is the one :). im going for RBK 50 which consists of 1 router and 1 satellite, if when i purchase this not  enought and i just want to extend slightly, can i buy any satellite model, by it the orbi plug too?
Thanks
  • I have a fairly large 2 story as well.  I have quite a few devices and some thick walls, and I wound up with 3 satellites.  All work very well together and I am pleased with the Orbi system.  If oyu don;t need strong signal in every room the current configuration you have might be sufficient, but I needed signal in every bedroom upstairs (lots of guests, etc).  Hope that helps.
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
    I have a 5000sq ft home and use just the base and 1 satellite with 40 feet in between. Have great coverage and performance.
    • RudigerGatt's avatar
      RudigerGatt
      The house is a total of 4000sqm, its not all open plan. If i did buy the 2 system package and needed another satetllite, could i buy any orbi satellite or does it have to be a specific model like my package?
      • FURRYe38's avatar
        It's best to keep similar model satellite to maintain same wifi speeds across the board. However you can connect different model satellites.
