Chadweasel
Mar 05, 2018Aspirant
Orbi Satellite and firmware problems
I recently installed my orbi system with a satellite. My problem is my satellite has the same name as my router but the satellite still uses the factory password while my router is using the password ...
- Mar 05, 2018
You can't set the password on a satellite via its UI page, there's no such option. You might try, after verifying the router and satellite are connected, to reset the password through the router (change it to something, then change it to the desired one). This worked for me when I had a similar problem where the satellite didn't get a full sync and still had the factory default.
bfeley
Mar 05, 2018Initiate
I, like many others, am done with Netgear Orbi. I work from home and need my wifi to perform reliably, anything short of that reflects on me negatively as a professional. I purchased eero a week ago, and wifi has been rock solid ever since; not a single issue. Time to sell my Orbi and recoup at least some of my worthless investment... never again Netgear.
