Chadweasel
Mar 05, 2018Aspirant
Orbi Satellite and firmware problems
I recently installed my orbi system with a satellite. My problem is my satellite has the same name as my router but the satellite still uses the factory password while my router is using the password ...
- Mar 05, 2018
You can't set the password on a satellite via its UI page, there's no such option. You might try, after verifying the router and satellite are connected, to reset the password through the router (change it to something, then change it to the desired one). This worked for me when I had a similar problem where the satellite didn't get a full sync and still had the factory default.
Mar 05, 2018Guru - Experienced User
The OP only mentioned that his problem is with the Satellite not getting same log in info as router. Hasn't said his system isn't working well.
- ChadweaselMar 05, 2018AspirantMy system is working well other than the problem in my original post. The range of the extender is far better than anything else I’ve tried.
