Seattlites
Mar 18, 2017Aspirant
ORBI Satellite cannot connect
No matter what I do and where I place the satellite, even in areas where I have a strong WiFi signal from the base unit, it will not connect and always provides the magenta light. The base unit has the latest firmware, however, the satellite because it has never connected, does not.
Have you factory reset the Sat ?
- 5597jadeAspirant
all moden connected bu still not owrking
 - SeattlitesAspirant
Thanks. Reset worked and I was then able to update firmware separately.
good to hear... if you update the software later, it was recommended to me to update the Sat first and then the Main..
Do this by the manual updating option ( download sw to computer first ) and not the automatic method
- 5597jadeAspirant
Connected to moden by still not working
do you have a phone number can call and talk ?
