bjbatlanta
Aug 31, 2016Initiate
Orbi Satellite Connection via Ethernet
Is it possible to connect the Orbi Satellite via an Ethernet connection so that it has a stronger signal to broadcast? My home is wired for ethernet and I'd prefer to take advantage of that fact tha...
- Dec 19, 2016
W2HX2 wrote:Dear peteytesting
I have seen you post about using another AP solution if ethernet wiring is available. I would be very interested in the names/models of some simple wireless access point products that will allow me to share the SSID which is really what I am looking for. I believe my house could easily be covered with three WAPs, the locations of which all have wired ethernet. So I am really just looking for a better access point solution. One that will allow shared SSID and also coordinated roaming from one to the other.
thanks
hi
the ubiquiti unifi ap's are the goto option the unifi ac lite is the best value for money
btw no matter what you get you can just name all the ssid the same and passphrase you just use different channels
seany187
Sep 25, 2016Star
Has anyone created an idea for this yet on Netgear's site? I can't find it. I REALLY want this feature.
JMU1998
Feb 25, 2017Luminary
Please request it here there is a separate idea request those who want this feature can request here:
https://community.netgear.com/t5/Idea-Exchange-For-Home/Netgear-Orbi-Wired-Sattelite/idi-p/1145210
