Yonijo
Dec 19, 2017Tutor
Orbi Satellite Connection via Ethernet
Hello I need to connect my orbi satellite in Ethernet wired. Is it possible now or I have to wait an other firmware ? Thank you for your help
- Dec 20, 2017
Hello Yonijo
You will need the to update your Orbi unit to the 2.1 firmware if you check for updates on your unit it should be available to download.
DarrenM
Retired_Member
Dec 19, 2017each Sat has 3 or 4 ethernet ports. are you wanting to connect other devices to your sat?
- YonijoDec 19, 2017TutorHello
Thanks for your reply
I want to connect the two satellites together
(Not by WiFi)- DarrenMDec 20, 2017Sr. NETGEAR Moderator
Hello Yonijo
DarrenM
- YonijoDec 20, 2017Tutor
Hello DarrenM
Thank you for your reply. I can show the wired connection between my two 2 satelite.
Thank to all netgear team for this new feature.
I have one more question in the configuration website on the satelite, i see the internet and the gateway in grey color (not in blue)
You think all it's ok ?
Regards
Yoni
