Yonijo
Dec 19, 2017Tutor
Orbi Satellite Connection via Ethernet
Hello I need to connect my orbi satellite in Ethernet wired. Is it possible now or I have to wait an other firmware ? Thank you for your help
- Dec 20, 2017
Hello Yonijo
You will need the to update your Orbi unit to the 2.1 firmware if you check for updates on your unit it should be available to download.
DarrenM
Yonijo
Dec 19, 2017Tutor
Hello
Thanks for your reply
I want to connect the two satellites together
(Not by WiFi)
(Not by WiFi)
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
Hello Yonijo
DarrenM
- YonijoDec 20, 2017Tutor
Hello DarrenM
Thank you for your reply. I can show the wired connection between my two 2 satelite.
Thank to all netgear team for this new feature.
I have one more question in the configuration website on the satelite, i see the internet and the gateway in grey color (not in blue)
You think all it's ok ?
Regards
Yoni
- cvoiseyDec 20, 2017Guide
I'm looking at the same, but I don't see any details on this anywhere. Are you saying that you were able to successfully just connect an ethernet cable between your router and the satellite(s) and it worked? No special ports to use or anything?
NOTE: I see the note about upgrading your firmware, but I still don't even see this documented in that FW release notes.
Thanks!! Honestly, I was about to return these as I have a really tough time getting wireless to one area of my house due to the style of construction. It's basically a faraday cage put right in the middle of my house!
- reffrDec 20, 2017Initiate
So, I have the Orbi router in AP mode. I have the two satellites connected to my router (not the orbi). The Orbi router cannot see the satellites. I thought that we could hard wire the satellites now. I'm on the latest firmware (2.1.1.16 on router and all satellites).
Am I wrong on how I can connect this?
