Yonijo
Dec 19, 2017Tutor
Orbi Satellite Connection via Ethernet
Hello I need to connect my orbi satellite in Ethernet wired. Is it possible now or I have to wait an other firmware ? Thank you for your help
- Dec 20, 2017
Hello Yonijo
You will need the to update your Orbi unit to the 2.1 firmware if you check for updates on your unit it should be available to download.
DarrenM
DarrenM
Dec 20, 2017Sr. NETGEAR Moderator
Hello Yonijo
DarrenM
Yonijo
Dec 20, 2017Tutor
Hello DarrenM
Thank you for your reply. I can show the wired connection between my two 2 satelite.
Thank to all netgear team for this new feature.
I have one more question in the configuration website on the satelite, i see the internet and the gateway in grey color (not in blue)
You think all it's ok ?
Regards
Yoni
