silasgreat
Jun 12, 2018Follower
Orbi Satellite Connection via Ethernet
I have been trying so hard to connect my orbi satellites via cable(Cat5) but it is not communicating. Everything looks good and I am already in AP mode and my firmware version is 2-1-4.0. The satelli...
Jun 12, 2018Guru - Experienced User
What FW version is loaded on both router and satellite? Should be same.
Did you add the satellite via Wifi first, ensure you get the top led to turn BLUE?
You can do this if you place the satellite near the router, say 10 feet. Add the satelite first via wifi. Get the top led to turn BLUE then it should turn off. Then connect a LAN cable from the Orbi router to the satellite. The top led should come on and probably pulse white ON and off. Then it should turn BLUE. Give 5 minutes. If you get the BLUE led on top then it goes OFF, turn OFF the satellite and take it to the remote place where you want it. Connect up the LAN cable there and power it on. Should be good to go.
