Shaun27
Jan 10, 2020Star
Orbi satellite disconnects
Hi I just purchased an Orbi 50 and a satellite. The satellite keeps disconnecting. It will flash white, then goes to blue and then reconnects. This units are only a week old. The router is fine. ...
- Jan 11, 2020
Ok.
seems the minimum distance between the router and satellite is 30 to 40 feet? So, the problem could well be they are too close.
Will end the thread here
meiqgu
Feb 06, 2020Initiate
i'm with you... the NG support is horrible... they kept asking you to do reset, reboot, check your modem... I have enough of this crap
meiqgu wrote:I have trouble of disconnect since day one I bought it from Costco. Spent too much time and engergy to talk to the support people. Currently if I unplug one satellite (mine comes with 2 satellites), i don't get drops. I did manually download the latest V2.5.1.8 and installed it,. It doens't help at all until I unplug 1 Satelitte. To me, it is their product defect. I have over 3000 sqft home, but my security cameras are within 7000 sqft area. I cannot always unplug 1. I have to, when I work, as my remote desktop has to keep connected. I'm waiting for NG to send me another one, fully tested. The one I'm using is already a replacement from NG. I have had enough patience to put up with this router... but I'm so attempted to return it and just get a different one now.
Shaun27 wrote:Hi Thanks.
Firmware is up to date. latest
Seems to me this is an issue many are experiencing? No real answer out there. So are only hope is for netgear to sort it. Shame really, the router is rock steady, my WiFi is excellent within what BT allows and what they call speed.
Sent a support note to Netgear, no reply......still waiting. My patience will come to an end soon.
Feb 06, 2020Guru - Experienced User
So the one user got his orbi working by putting more distance between the RBR and RBS if you didn't see this.
https://community.netgear.com/t5/Orbi/Orbi-satellite-disconnects/m-p/1847398/highlight/true#M80167
3000sq foot home maybe too small for having two RBS, Try using just 1. I have a RBK50 with just 1 RBS in a 5000sq ft home and it works with zero problems.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
