mikebp
Sep 17, 2020Aspirant
Orbi Satellite does not see Wired device
I'm connecting a wired Ethernet RTU to teh RBR50 Satellite and when configured for DHCP it is not "seen". If I configure the RTU device with a static IP - it is seen and connects perfectly. Why ...
Mstrbig
Sep 17, 2020Master
I would say look at the setting on the device and make sure your DHCP settings are correct.
If the problem persists, reset the network settings on the device.
