mikebp
Sep 17, 2020Aspirant
Orbi Satellite does not see Wired device
I'm connecting a wired Ethernet RTU to teh RBR50 Satellite and when configured for DHCP it is not "seen". If I configure the RTU device with a static IP - it is seen and connects perfectly. Why ...
Mstrbig
Sep 17, 2020Master
Unfortunately I don't think it is an Orbi issue, or all other devices would have DHCP problems. Can you factory reset the device or reset the network on the device?
Is it possible the device is defective? And as CrimpOn asked, can you provide the name of the device that is malfunctioning?
mikebp
Sep 18, 2020Aspirant
The Ethernet RTU is produced by Eybond: http://www.eybond.com/page193?_l=en#bb
Again it works with other routers in DHCP mode and works fine with a static IP - just doesn't seem to accept DHCP from the Orbi RBR50 (main or satellite). Access Control is disabled. Since it seems no IP is assigned, "arp -p" does not see the device either (not unexpected).
Any further diagnostic suggestions welcomed!
- FURRYe38Sep 18, 2020Guru - Experienced User
So with the RTU connected to the back of the RBR, reboot the RBR or power OFF the RBR for 30 seconds then back on.
Once the RBR is back to ready, check the RBRs web page to see if the device appears in the conneccted clients list.- mikebpSep 18, 2020Aspirant
Ok - (ashamed I didn't think of the old standard 'reboot/power-cycle') - 1st tried wired connectivity to the RBS50 (no-go) then relocated to the RBR50 - also a no-go. ...and no show on an "arp -a".
What FW version are you using on the Orbi?
Sounds like this device doesn't like the Orbi DCHP or vs versa. Something to contact NG support about.
- CrimpOnSep 18, 2020Guru - Experienced User
mikebp wrote:The Ethernet RTU is produced by Eybond: http://www.eybond.com/page193?_l=en#bb
My "go to" for issues such as this is Wireshark. On the Orbi debug page (http://orbilogin.net/debug.htm) check the box to Enable LAN/WAN Packet Capture. Click on Start Capture. Perform the test by plugging in the RTU (Remote Terminal Unit. These things look fascinating. Wish I had something to monitor!) Click on Save Debug file and a zip file will be written to the browser Download location. Inside the zip file are WinPCAP files for every packet that appeared on the WAN port and that hit the Orbi router LAN.
Wireshark should show the RTU sending a DHCP request. (Wireshark can filter the display by MAC address and protool.)
