mikebp
Sep 17, 2020Aspirant
Orbi Satellite does not see Wired device
I'm connecting a wired Ethernet RTU to teh RBR50 Satellite and when configured for DHCP it is not "seen". If I configure the RTU device with a static IP - it is seen and connects perfectly. Why ...
Sep 18, 2020Guru - Experienced User
So with the RTU connected to the back of the RBR, reboot the RBR or power OFF the RBR for 30 seconds then back on.
Once the RBR is back to ready, check the RBRs web page to see if the device appears in the conneccted clients list.
mikebp
Sep 18, 2020Aspirant
Ok - (ashamed I didn't think of the old standard 'reboot/power-cycle') - 1st tried wired connectivity to the RBS50 (no-go) then relocated to the RBR50 - also a no-go. ...and no show on an "arp -a".
- FURRYe38Sep 18, 2020Guru - Experienced User
What FW version are you using on the Orbi?
Sounds like this device doesn't like the Orbi DCHP or vs versa. Something to contact NG support about.
- mikebpSep 18, 2020Aspirant
It's version: V2.5.1.16.
...was hoping one of you 'guru's out there would have a means to identify/isolate who's not behaving.
Appreciate all your input...
Sounds like the RBR either isn't ACK to the ARP request of the device or the device is not ACK back to the RBRs ARP request.
Something I would wireshark capture and send off to both NG and the device mfr to see where the problem maybe.
