mikebp
Sep 17, 2020Aspirant
Orbi Satellite does not see Wired device
I'm connecting a wired Ethernet RTU to teh RBR50 Satellite and when configured for DHCP it is not "seen". If I configure the RTU device with a static IP - it is seen and connects perfectly. Why ...
mikebp
Sep 18, 2020Aspirant
It's version: V2.5.1.16.
...was hoping one of you 'guru's out there would have a means to identify/isolate who's not behaving.
Appreciate all your input...
Sep 18, 2020Guru - Experienced User
Sounds like the RBR either isn't ACK to the ARP request of the device or the device is not ACK back to the RBRs ARP request.
Something I would wireshark capture and send off to both NG and the device mfr to see where the problem maybe.
