mikebp
Sep 17, 2020Aspirant
Orbi Satellite does not see Wired device
I'm connecting a wired Ethernet RTU to teh RBR50 Satellite and when configured for DHCP it is not "seen". If I configure the RTU device with a static IP - it is seen and connects perfectly. Why ...
Mstrbig
Sep 18, 2020Master
mikebp wrote:It's version: V2.5.1.16.
...was hoping one of you 'guru's out there would have a means to identify/isolate who's not behaving.
Appreciate all your input...
I'm going to assume your model is the Ethernet RTU?
First let's start with How do you have it connected to the RBR50?
mikebp
Sep 18, 2020Aspirant
It's a direct wired-Ethernet connection to one of the 4 ports on either/both the RBS or the RBR (one router one satellite - 3-4 other wired devices connect with no issue - as does the RTU when configured with static IP). Doesn't matter which unit it's plugged into. Been through all permutations of power cycling & rebooting to no avail.
