bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
worldturning
Aug 11, 2017Star
Same problem with satellite disconnects as the original thread poster. 3-pack Orbi in router mode with satellites losing connection/internet at least a couple of times a day. ISP is Comcast/Xfinity. Can have up to 37+ devices connected at one time including multiple Apple & Android devices, pc's/laptops, Xbox, Kindle, Philips Hue lights, Belkin Wemo plugs/lights, Nest cameras, Arlo Pro cameras and DirecTV boxes.
Originally purchased the 2-pack back in October 2016, but ended up installing that in a relative's house and purchased the 3-pack (from Costco) when that was released to cover dead spots on opposite sides of the house where additions were built. All had been working well for the past 9 or so months until firmware 1.12.0.18. Previous to 1.12.0.18, the only issue was the outdoor Nest cameras disconnecting maybe once or twice a day for about 10 minutes which was resolved by unchecking implicit beamforming (left MU-MIMO checked).
Now with this firmware, the satellites to lose connection once or twice a day. To get the satellite connection back, it needs to be turned off then on again. Once a satellite is turned back on, after the progression from solid white to flashing white for a minute or so, the light turns to solid blue and stays that way with no internet connection. Then need to press the synch button to eventually get the satellite connection back. Main router does not lose the internet.
With firmware 1.12.0.18 and only MU-MIMO checked, Nest outdoor cameras are having intermittent issue with disconnecting for 10 minutes or more again though not every camera and not every day. Same result when both implicit beamforming and MU-MIMO are checked with firmware 1.12.0.18.
I also have two Arlo Pro base stations, one connected to the router and the other to one of the satellites. Ever since firmware 1.12.0.18, the internet connection led flickers 3-5 times every few seconds or so then goes back to solid then back to the intermittent flickering/blinking. The internet led remained solid green before the 1.12.0.18 firmware update. In fact, another way to tell when the satellite loses connection is when the internet led of the Arlo Pro base station connected to it turns to orange.
Very frustrating. Netgear needs to resolve this ASAP.
- DranikAug 12, 2017Initiate
Same thing here. One minute phone works fine, then it shows full signal but no internet connection and later it goes back to the internet connection being ok. It was happening every 5 minutes. After reading this I unplugges the sattelite and never had the same issue again. So there is definitely something wrong with the way satellite connects to the base. Last year I promised myself never buy NETGEAR stuff again, and here I am... should've kept my promise...
- IDGuy42Aug 12, 2017Guide
I'm having the same issue. I've noticed it on my MacBook Pro, Android Galaxy S7 and two Google Home devices. I notice it on the Google Home the most because it doesn't recover and gives me an error message when trying to talk to it.
I have the RBR50, two RBS50s and a RBW30. All on the latest firmware.
Thanks
IDGuy42
- psimondoNov 01, 2018Star
exactly my issue. incredibly annoying. Makes the whole system broken just like my previous solutions (except previous setup was cheap)
- FURRYe38Nov 01, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try disabling the following and see:
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001Try a Manual FW load:
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-released-as-of-10-3-18/m-p/1647303/highlight/true#M42416
- Sb-RbDec 22, 2018Tutor
These complaints were generated in 2017. My system also drops internet and all arlos drops off. Satellite directly connected to Netgear router for arlo. Still no connection. Appears Netgear and arol companies don't have a fix for these devices and 2019 is around the corner. Ever notice that Netgear never posts the fix but instead asks you to private message your email and phone number, then never fixes the problem.
- psimondoDec 22, 2018StarI did find something that helped me.
Reduce 5GHz band to 75% power
Reduce 2.4GHz band to 50% power
My conjecture is that the power of the main station was sometimes more powerful than the satellite, so devices kept switching between them. Then eventually messing up the whole thing requiring a hard reboot.
Reducing transmission power, specifically making 2.4 lower than 5 (it has greater range), really has made my setup MUCH more stable.- Sb-RbDec 22, 2018Tutor
How did you alter the bandwidths? I am now having trouble accessing my account online and both Netgear and Arlo tech supports were useless to help. Netgear said it was Arlo's problem and all Arlo did was have me reset the password to access my camera account. Anyone know anything at all in these corporations???
