bluefish10
Aug 01, 2017Guide
Orbi satellite dropping connection
Right to the point: my Orbi system has 2 satellites and 1 main tower. The internet drops/slows down (to the point where internet browsing is not possible) 2-3 times per day randomly without warning o...
nxh786
Aug 08, 2018Aspirant
Sick and tired of this mess!!! I've so many Netgear products but this is a huge mistakmistake. I've tried changing all sorts of settings but no improvements. I'm supposedly on the latest firmware .
- FURRYe38Aug 09, 2018Guru - Experienced User
What is the Mfr and model# of the IP modem the Orbi is connected too?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).Can try the configuration I used on my friends system:
If you feel your not getting anywhere, I recommend contact NG support or taking the system back to place of purchase...
