Squeeian
Jan 23, 2018Follower
Orbi satellite dropping connection
My orbi satellite won’t connect. I’ve tried syncing it and even reset the satellite. I called tech support previously, they seemed to help me fix it by resetting it, but when I tried doing it myself, it didn’t work. Please help.
1 Reply
Sort By
- linkwrtGuide
Squeeian wrote:
My orbi satellite won’t connect. I’ve tried syncing it and even reset the satellite. I called tech support previously, they seemed to help me fix it by resetting it, but when I tried doing it myself, it didn’t work. Please help.How i fixed:
- i set RBR50 (router) to United States
- i set 2.4Ghz and 5Ghz channels to AUTO
- i checked Enable Daisy-Chain Topology
- i enabled BEAMFORMING
- i enabled MU-MIMO- i did a reset to default factory satellite, then after reboot it connected automatically to RBR50 router.
Please note that after firmware upgrade i did a reset to factory defaults for both Router and Satellite.
