NetworkDude696's avatar
Mar 19, 2019
Orbi Satellite dropping connection
I am having issues with my Orbi Satelitte.  My orbi satelitte is connected directly to my computer through ethernet.  It is about 15 feet away from the main unit and modem.  When I connect my compute...
  • NetworkDude696's avatar
    NetworkDude696
    Mar 28, 2019
    I did update my firmware.  I used a direct connection using ethernet from my modem to my computer without the Orbi at all.  I then captured the exact moment the issue happened twice with wireshark.  I watched packet loss happen directly on my other screen in wireshark.  I think at this point its obviously not the Orbi and I need to get the ISP invovled.  I am sure its a cabling issue from the drop line to my place.
    I appreciate all the help! I am glad its not the Orbi!
