kwtb2488's avatar
kwtb2488
Orbi Satellite Failing to Sync
Hi ive had the Orbi wireless system in my two story condo for a few years. The upstairs internet sometimes is spotty (i have the Orbi downstairs) so i got another satellitte to help improve it. However when setting it up i cant get anything but the magneta color. I have the Orbi satellitte placed directly above the room where its at so im not sure how to get it any closer without actually moving it downstairs which seems like it would be against the whole reason of getting the extra satellite to begin with.
Anyone have any idea or reccomendation as to what I can do?
  • CrimpOn's avatar
    CrimpOn
    My practiced has been to sync the satellite in the same room as the Orbi so that I can watch both of them as it happens.  After the satellite syncs and the Orbi web interface reports "good", then I relocate the satellite to the remote location.
    Immediately above (or below) the Orbi router is probably not as desirable as being "offset".  WiFi access points typically have omnidirectional antennas which radiate mostly in the horizontal plane.  After it syncs correctly next to the router, you can try moving it around to see which location gets a "good" connection.
  • FURRYe38's avatar
    Make sure both RBR and RBS are on the same version of FW.
