flamenca
Sep 24, 2018Tutor
Orbi satellite flashing and not pulsing white
I bought another Orbi RBS 50 to work with my existing system. I have an existing Orbi router and one satellite and wanted to extend the WiFI system in my house. As soon as I connected the new Orbi...
Sep 24, 2018Guru - Experienced User
FW on the new satellite needs to be updated first:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-Satellite
- flamencaSep 25, 2018Tutor
Thank you for your prompt response. No problem downloading the information to update the firmware for the new satellite but as it has not connected to the router when I go to manual update it will only display the original satellite Orbi. I note that the new satellite Orbi is running on V1.12.0.18 and my system is running on V2.1.4.16 but how do I get the firmware to update when it willnot display.
