pipiche38
Nov 18, 2019Aspirant
Orbi satellite pas d'adresse IP - RING LED Fushia (RBS50)
Voila, depuis pas mal de temps, j'essaie de connecter un Satellite ORBI RBS50 sur mon la base router RBR50, mais sans succès. Lorsque je démarre le RBR50, j'ai l'anneau qui clignote blanc, puis Blue et très rapidement fushia. Il y a 7 mètres entre le RBR50 et le Satellite, j'ai essayé - de le rapprocher du RBR50 ( environ 2 mètres ) sans résultats - de faire un full reset (factory) sans résultats -RBR50 est en version 2.5.0.38 PS/ A quelques rares occasion il s'est synchronisé, ce qui m'a permis de le monter également à la dernière version, mais il ne reste Ok que quelques jours puis c'est de nouveau la galère
I'm posting here after in English, as it is confusing for me to have the Forum in French with English content. Sorry for that
SO I have an RBS50 (Satellite) that I want to connect to an RBR50, and which is giving me very hard time. It works some time, but most of the time it doesn't.
Basically during the startup process the RBS50 got:
Led Ring white flashing
Led Ring Blue flashing (very short time)
Led Ring Fushia
I have tried to move the RBS50 around from 7m (where I want it to be ) to much closer ( 2 meters) and never succeed !
Attached is the Wifi setup
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).This is the Orbi forum for English users. For French users, please post here:
https://community.netgear.com/t5/Orbi/bd-p/fr-domestique-orbi
Good Luck.
- pipiche38Aspirant
There is a router in front if your RBR. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Then use the Orbi router in router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
