Donathon
Aug 06, 2017Aspirant
orbi satellite rbs50 led issue
My 6 month oldorbi rbs50 setellite router led lights just started to keep coming on and cycling through the colors. I dont remember this happening before Things seem to work ok. Is this normal? ...
DarrenM
Aug 10, 2017Sr. NETGEAR Moderator
Hello Donathon
How often is it happening? is it mostly one color?
DarrenM
Donathon
Aug 10, 2017Aspirant
lights seem to cycle between: none, blue, magenta
multiple times a day, 24/7. However, I looked at the Orbi app when lites are on and it showes a satellite connected.
Donathon
DarrenM wrote:Hello Donathon
DarrenM
- DarrenMAug 10, 2017Sr. NETGEAR Moderator
I would try to factory reset the satellite and then resync it see if that helps.
DarrenM
