kchummons
Nov 13, 2023Follower
Orbi Satellite RBS50 synch lights do not come on and will not sych
The synch lights will not light up and therefore the router will not synch to the network. I have followed all instructions and reset the entire system, including bringing the satellite router into the same room as the Orbi Router RBR50. Any suggestion?
Be sure FW on the RBR is same on the RBS.
Does the RBS sync up any or gain an IP address if you ethernet connect the RBR to the back of the RBR with a ethernet cable? https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
- KevinLiTNETGEAR Moderator
Hello kchummons ,
Welcome to the NETGEAR Community!
I understand that you are not able to sync your RBS50 to your RBR50. This can be caused by a difference in firmware between your RBR50 and your RBS50. Please ensure that the firmware that is installed on your RBR50 matches the firmware that is installed on your RBS50. A firmware update will need to be performed if there is a difference in firmware between your devices.
Please navigate to our knowledge-based article below for step-by-step instructions on how to update your RBR50/RBS50 firmware:
How do I manually upgrade firmware on my Orbi router using orbilogin.com? - NETGEAR Support
Please navigate to the link below for the firmware download file for your RBK52 Orbi Mesh System:
https://www.netgear.com/support/product/RBK50#downloadLet us know if you have any additional questions!
Best,
Kevin
community Team
