Salmon
Jan 16, 2018Tutor
Orbi Satellite SUPER SLOW
Got my Orbi this afternoon and just set it up. Must say, I'm extremely disappointed. In my livingroom, next to the router, I get 62 Mbps. Awesome! My service is "up to 60 Mbps" so I'm very hap...
linkwrt
Jan 23, 2018Guide
DarrenM wrote:Have you tried to adjust the wireless channel? also in the advanced wireless settings try to enable beamforming and mumimo see if that changes the speeds.
DarrenM
Update firmware to both router and satellite.
Do a reset to factory default to both.
Set rbr router.
Satellite should be detected by rbr router if not try to sync.
Enable Mu-MIMO and beamforming.
Use United States for wireless country or Australia.
gud2seau
Feb 08, 2018Aspirant
Enabling MU-MIMO was causing the problem for me. Fast roaming and beam forming are fine. But, once I enable MU-MIMO, speeds go from 60-70MB download to 1-3.
