Taybraham
Jul 02, 2019Follower
Orbi satellite trouble
Every night I have to unplug my orbi satellite and plug it back in in order to use the smart function on my new Roku tv. I am new to Orbi as well and was really excited about being able to extend the WiFi to reach my bedroom tv. I have another tv (Vizio) not too far away and don’t seem to have this issue so I thought it may be my roku tv but once I unplug and replug the satellite it works just fine. Its a pain to have to do it every night and wait for it to reconnect when I want to watch tv.
1 Reply
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
