Dilev's avatar
Dilev
Follower
Jul 23, 2020
Orbi satellite wall plug satellite is not working
The model is RBW 30 We have the router plus 2 satellites and the wall plug. When the RBW30 is plugged in it shows a pale purple color. I have tried to reset it. The color is amber and then goes to a solid pale purple and remains like this. We do not get internet near the unit. Thank you
1 Reply
  • FURRYe38's avatar
    Try connecting the RBSW near or in the same room as the RBR. Factory reset and press the sync button on the RBS and RBR.
    The other RBSW works?
