macksuttonus
Nov 26, 2017Aspirant
Orbi Satellite will not connect to router or show in AP or Attached devices
I have a RBR50/RBS50 that I setup today. The satelite never went to a solid white LED during setup and would not connect to the router. I setup both devices in the same room to ensure distance was ...
macksuttonus
Nov 28, 2017Aspirant
Unfortunately, when I try to connect to 192.168.1.250 when connected to the satellite through an ethernet connection, I get a site can't be reached error.
Heiruspecs
Nov 29, 2017Guide
macksuttonus wrote:Unfortunately, when I try to connect to 192.168.1.250 when connected to the satellite through an ethernet connection, I get a site can't be reached error.
I had the same issue earlier. The trick seemed to be to push the reset button on affected devices for a full minute (40-60 seconds) and let them boot up fully (~2 minutes or so). After this, my device kept blinking white aswell, but this time I could continue with the setup, find my satellites and get everything up and running. You may need to push the Sync button on your satellite (for up to 10 seconds), while a quick push on the router should be enough. I did this until the setup found my satellite (could take a few tries).
This has worked for a few others aswell, give it a try!
- macksuttonusNov 30, 2017Aspirant
That didn't work either. After about a dozen attempts, I've stopped trying to sync. I'll probably have to return this system and get a replacement.
