jblack68's avatar
jblack68
Apprentice
Aug 30, 2018
Orbi Satellite will not reconnect unless I disconnect all ethernet devices first
Hi,
I have recently figurered out why my Satellite will not reconnect to my Orbi Router because there was ethernet devices connected to the Satellite - once i removed them and rebooted Satellite - connects fine.
Anyone had this issue before - if i disconnected Satellite and it will try and connect but would be listed as *Attached Devices* on the Orbi Page and Speeds will be limited to 10mbps
1 Reply
  • FURRYe38's avatar
    What FW is currently loaded?
    What LAN devices do you have connected to the satellite?
    MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
