ccigas
Dec 11, 2016Tutor
Orbi Satellite Wiring
Hello, I am looking to get a wifi mesh system for my house and was curious if the Orbi and the satellites could be wired together to create a better connection for the wifi? I know the Eero and ...
netwrks
Dec 11, 2016Master
Orbi is not a mesh system. The wireless extnders communicate with the base router using wireless backhaul (more of a start topology). You can configure the Orbi to run in Access Point mode (Ethernet connection back to a router in your network). (Orbi Review)
ccigas
Dec 11, 2016Tutor
Would you need an Orbi router for that or could I use the satellites on my own router, an ASUS RT-AC88U.
- netwrksDec 11, 2016Master
The sats (extenders) work weith the Orbi only..
- ccigasDec 11, 2016Tutor
Ok I understand now, and this will work if I wire them together right?
If you are talking about Ethernet connecting the Orbi router ( configured in Access Point mode) to your Asus, then yes. Let the Asus be your DHCP Server. The Satellites that come with the Orbi are wireless - no cables.
