ccigas
Dec 11, 2016Tutor
Orbi Satellite Wiring
Hello, I am looking to get a wifi mesh system for my house and was curious if the Orbi and the satellites could be wired together to create a better connection for the wifi? I know the Eero and ...
netwrks
Dec 11, 2016Master
The sats (extenders) work weith the Orbi only..
ccigas
Dec 11, 2016Tutor
Ok I understand now, and this will work if I wire them together right?
- netwrksDec 11, 2016Master
If you are talking about Ethernet connecting the Orbi router ( configured in Access Point mode) to your Asus, then yes. Let the Asus be your DHCP Server. The Satellites that come with the Orbi are wireless - no cables.
- ccigasDec 11, 2016Tutor
No I mean from the Orbi router to the satellites. If I bought this I wouldn't be able to run a cable from one of the 3 LAN ports on the Orbi router to one of the four LAN ports on any of the satellites? Just like putting a second router in a bridge mode which I have now?
So even though this is a tri-band product they take a step back and not allow wired connections unlike Google Wifi, not sure about Eero. That is kind of annoying, I would rather have the ability to wire my satellites for a more stable connection.
- peteytestingDec 11, 2016Hero
ccigas wrote:So even though this is a tri-band product they take a step back and not allow wired connections unlike Google Wifi, not sure about Eero. That is kind of annoying, I would rather have the ability to wire my satellites for a more stable connection.
its not a step back , its the way its designed
why would you want any of these expensive mesh systems anyway if you already have structured ethernet cabling , this makes no sense to me just get some working AP's and away you go and prob cheaper than any of these mesh systems anyway
the orbi is designed for those that dont have / want or cant have structured ethernet cabling , it might be nice if it did it but the logic of buying the orbi wouldnt make sense , this would be the same for google wifi or eero etc etc , to use ethernet to connect the end points removes the one thing they are tring to achieve and thats whole home wifi coverage without the need for wires
