ccigas
Dec 11, 2016Tutor
Orbi Satellite Wiring
Hello, I am looking to get a wifi mesh system for my house and was curious if the Orbi and the satellites could be wired together to create a better connection for the wifi? I know the Eero and ...
peteytesting
Dec 11, 2016Hero
ccigas wrote:
So even though this is a tri-band product they take a step back and not allow wired connections unlike Google Wifi, not sure about Eero. That is kind of annoying, I would rather have the ability to wire my satellites for a more stable connection.
its not a step back , its the way its designed
why would you want any of these expensive mesh systems anyway if you already have structured ethernet cabling , this makes no sense to me just get some working AP's and away you go and prob cheaper than any of these mesh systems anyway
the orbi is designed for those that dont have / want or cant have structured ethernet cabling , it might be nice if it did it but the logic of buying the orbi wouldnt make sense , this would be the same for google wifi or eero etc etc , to use ethernet to connect the end points removes the one thing they are tring to achieve and thats whole home wifi coverage without the need for wires
rwiegand
Jan 31, 2017Aspirant
"why would you want any of these expensive mesh systems anyway if you already have structured ethernet cabling , this makes no sense to me just get some working AP's and away you go and prob cheaper than any of these mesh systems anyway"
I'd like to have a seamless single wifi network. Right now my barn/shop is too far from the wireless AP in the house to give a useable connection, while still being too strong to have devices like my phone switch automatically to the AP in the barn that is hard wired to my network. I end up manually resetting the wifi connection on my phone 10 times a day as I go back and forth. Not fun.
Apparently Orbi won't work for what I want, but I've been many places where such sysems work perfectly. My Google Fu has not yet been up to uncovering how one achieves this. Any help would be much appreciated.
