Orbiless
Sep 07, 2017Aspirant
Orbi satellite won't reconnect to Orbi router, only appears as a Device
Pls help if u can... I set up a new Orbi system in half hour in Access Point mode, no problems, satellite connected straight up, internet connection all good, awesome performance. Then, last thing ...
peteytesting
Sep 11, 2017Hero
so if you can see the sat in the attached device list get its ip address and enter it into your browser address window , this should open the sats web gui and you can choose to update the firmware from there
- OrbilessSep 11, 2017Aspirant
Thank you. This was one of the solutions we tried with the Support team by phone, but for some reason, entering the listed IP address into the browser only opens my browser home page (internet explorer 11). Tried this multiple times, with same result each time. I suspect that if we could open the web gui it would have been a fix, that's where we were trying to get to. Thanks again.- peteytestingSep 11, 2017Hero
did you try with a different browser
- OrbilessSep 13, 2017Aspirant
Only on IE11 and google. Same result each time.Thans for the suggestion.
