Orbiless
Sep 07, 2017Aspirant
Orbi satellite won't reconnect to Orbi router, only appears as a Device
Pls help if u can... I set up a new Orbi system in half hour in Access Point mode, no problems, satellite connected straight up, internet connection all good, awesome performance. Then, last thing ...
peteytesting
Sep 12, 2017Hero
did you try with a different browser
Orbiless
Sep 13, 2017Aspirant
Only on IE11 and google. Same result each time.Thans for the suggestion.
- OrbilessSep 15, 2017Aspirant
OK, after getting a replacemen t set, which auto-updated overnight, downloaded Firefox browser and tried that. It worked! but told me that both Satellite and Router are updated to the same firmware version. I even reloaded the current firmware version to the Satellite to make sure it got the picture, but still no difference: Satellite is impotent - only appears as a connected device and not a Satellite. Thanks for the suggesntion, but no win here.Still Orbiless.
