terrychau's avatar
terrychau
Orbi Satellites connecting intermittently
I've got an RBR50 with 2 RBS50 satellites.  My son was complaining about connectivity issues in his room even though his room is only down the hall from the RBR50 which is in my office, originally we had only one RBS50 satellite located downstairs.  Since he was having connectivity issues I purchased a second RBS50 satellite and located it between my office and his room.  It seemed to work fine for a while until he started complaining about intermittant connectivity.  I would check my connection and had no issue so I thought he may have had an issue with his setup.  This has been going on since January.  Fast forward to this week, I finally logged a ticket with Gearhead support and noticed that the speed on the second satellite was fluctuating between 5GHz and 2.4GHz and also intermittently drops.  Gearhead support changed the channels for the wifi from Auto to specific channels which I thought helped, but low and behold, the connectivity issue recurred.  I finally swapped the location of the original satellite I had (which was not giving us any problem) with the newer one and the connectivity seems to be better.  I will continue to monitor, but has anyone ever come across a like issue before or can provide clarity of why swapping the satellites rectified the issue assuming that this resolved the issue (knock on wood)?
Thanks for your feedback
  • Sometimes you could tell it is probably got disconnect from the router from the colour ring but sometimes it just not connecting to the Internet. At all time devices connecting directly to the router work just fine. So should be the satellite issue.
    www.upsers.com
  • FURRYe38's avatar
    What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
    What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
    • terrychau's avatar
      terrychau
      What Firmware version is currently loaded? V2.7.2.104
      ATT Internet Gateway 2Wire 5268AC
      What is the size of your home? 2-stories Sq Ft? 2500
      Satellite-1 50 ft
      Satellite-2 10 ft only because of intermittant connectivity in a room 20 ft away from RBR
      2.4Ghz channel 1
      5Ghz channel 44
      Any Wifi Neighbors near by? Yes
      • FURRYe38's avatar
        Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
        Couple of options,
        3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
        Satellite-1 50 ft
        Satellite-2 10 ft only because of intermittant connectivity in a room 20 ft away from RBR< 10 feet is too close. 30 feet or more in between...
        2.4Ghz channel 1
        5Ghz channel 44
        Any Wifi Neighbors near by? Yes < What channels are they using?
