tjstansell
Nov 27, 2017Aspirant
Orbi satellites not showing in connected devices - Circle incompatibility
I recently purchased an RBK53 kit and got things set up. It came with the 1.8.x firware pre-loaded and while it wasn't quite as seamless of a setup as I would have hoped (had to reset/reboot the sat...
DarrenM
Nov 30, 2017Sr. NETGEAR Moderator
Hello tjstansell
I have sent you a PM
DarrenM
- VR7Nov 30, 2017Aspirant
Just purchased and conencted a second satellite (RBS50) to my router without issues (blue light). However, it doesn't show up as a second satellite. From the logs pasted below, I could make out it was "denied" entry (??)
Logged into the new satellite's IP addres through a browser and was able to see it was connected to the router without issues.
Have not restarted or reset router. Didn't have to. However, would like to be able to see the satellite on the connected devices list so that firmware upgrades can be done and such. Firmware being used is 2.0.0.74.
A secondary issue - my nest cam is connected to my wifi network through a guest network but is not visible in the list of visible devices. Other devices using guest network are.
Any help would be appreciated. Thanks.
------------------Logs-------
[DoS Attack: ARP Attack] from source: 192.168.X.X, Thursday, November 30, 2017 16:22:10
[admin login] from source 192.168.X.X, Thursday, November 30, 2017 16:00:27
[DoS Attack: ARP Attack] from source: 192.168.X.XX, Thursday, November 30, 2017 15:47:33
[Access Control] Device unknown with MAC address XXXXXX is allowed to access the network, Thursday, November 30, 2017
