tjstansell
Nov 27, 2017Aspirant
Orbi satellites not showing in connected devices - Circle incompatibility
I recently purchased an RBK53 kit and got things set up. It came with the 1.8.x firware pre-loaded and while it wasn't quite as seamless of a setup as I would have hoped (had to reset/reboot the sat...
mthomtech
Dec 03, 2017Tutor
Thanks for this info. I just hooked up Orbi with 2 satellites and everything was running fine, until I made some fine tuning and rebooted the Orbi router, and then I started losing my satellites. I also have Circle, and that was exactly what was causing my issue. I disconnected Circle and got the satellites back up and then turned Circle back on. I made sure to put my satellites as "unmanaged" in Circle to hopefully prevent future disconnections after reboots or power outages.
