steveee
Mar 18, 2018Follower
Orbi Satellites now only work in Ethernet mode.
I am really confused. My orbi system was delivered 3 weeks ago and worked on first setup. However it dropped connection and I went through pairing again. They all paired and all have the latest firmw...
tucsontico
Mar 18, 2018Virtuoso
You mention you have the "latest firmware". What is the firmware version number? Some people are having difficulty with v2.1.2.18. In fact, Netgear has recommended–if you're having problems–to downgrade back to v2.0.1.4. Also, how are your satellites configured? Do you have Daisy Chain selected? If so, try turning that off. Good Luck!
