karibeany
May 16, 2018Aspirant
Orbi setup —> no such file or directory
Had configured with AC1750 cable modem router and worked without problem for 7 months. Suddenly unable to connect to internet with orbi. Have reset both modem router and Orbi. Internet connection is g...
May 16, 2018Guru - Experienced User
Is the cable modem/router in router mode or bridged?
What mode is the orbi system using?
karibeany wrote:
Had configured with AC1750 cable modem router and worked without problem for 7 months. Suddenly unable to connect to internet with orbi. Have reset both modem router and Orbi. Internet connection is good (and even says so on orbilogin.net homepage). Firmware up to date. Finally reset Orbi router and with wizard setup, directs to routerlogin.net and says “no such file or directory.” Help!
